Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
mavicpilots.com
Since you live in UK, there are specific laws and rules for you to follow, please check to ensure these are current.
According to CAA, drones are allowed in the UK, subject to CAA regulations. Read on for more details.
drone-laws.com
Now, for some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic Air, including the User Manual.
At DJI Download Center, Learn aboutMavic Air
www.dji.com
Happy, Safe and Legal Droning…
