Hi from the "shake & bake" state-California
Player-Pe
Sacramento, CA, USA
New drone pilot here trying to get my feet wet in drone flying. I got a free Mavic Mini (although discontinued) through a company awards program and my first thought was to just go out and have fun flying. NOPE! Found out there are some serious FAA regulations on flying so I figured I'd do my due diligence and get legal so I don't have to fly looking over my shoulder. I first got my TRUST certificate to fly recreationally then just completed & passed the Part 107 just in case I fly commercial in the future. Never know. Hoping to learn a lot on this forum from experienced pilots. Thanks
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
As a New Drone Pilot, You are probably the most "Legal and Professional" Newbie we've had join in a long tome… So, I'll skip all the normal stuff I normally include.
However, here is some Good Old Fashion Advice that's not on any exam…
Below is the link to all of the downloads offered by DJI for the Mini, including the User Manual.
Happy Droning…
Happy Droning…
Thanks! Will do!
Welcome, Anything thats flies and free is even better :)
Heck yah!
Free is one of my favorite four letter "F" words. :D
Welcome to the forum! :)
Reactions: LoudThunder
Greetings from Colorado, USA🇺🇸, welcome to the forum🎄
keith Milligan
