I think this sounds like an opportunity you cannot miss. I suggest you bring a bright yellow or white landing "marker" to help you land exactly where you left from with your camera pointing directly downward. Once you have taken off, proceed slowly. At some point you may loose VIDEO connection. This means that you will soon loose RC connection at it is a warning that it is time to head back. You will simply use the map on your tablet to bring you back to your landing zone, point the camera 90 degrees downward and then slowly land on your target. Is there a risk? of course but you did not buy your Mavic to fly in your back yard. Have fun and post the videoI am not sure if this has been discussed, but how would you fly and land the Mavic in a forested area? Specifically, a tropical forest. All the threads I have seen is of the Mavic flying over open terrain with a few trees here and there....or over a coastline.
Assuming that you launch from a clearing, but beyond the clearing is the dense forest, with tall trees 50-65 meters tall. I would expect the GPS signal to be moderate at best, most likely weak.
Is it even possible to fly the Mavic like this? You can't even see the Mavic once it flies out of sight (and that will be very fast).
I bought some Range Extenders to hopefully increase the signal strength of the antennae, but I haven't had any chance to attempt this yet.
If anything goes wrong, the Mavic would probably end up in some tall tree branches and be stuck there forever....
Could this be the most challenging flight type for the Mavic (or any drone)?
The answer is 43.How much is the risk exactly?
Drone flying is all about knowing the risks and mitigating them. Since you obviously have no clue about the risk, since you ask, it is definitely a no go. Beyond VLOS, which is after only a few hundred meters, even over a winter forrest without leaves, you have no idea what the risks are. It could be low flying helicopters, bird attacks, and loss of control signal.The answer is 43.
