Hi team, new to the DJI ownership fraternity.
mavicpilots.com
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Find out what you need to know and do when you fly drones or model aircraft in the UK
register-drones.caa.co.uk
You wrote that you are New to the DJI Community, I will take that to mean Drones in general; therefore, here is some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the
Mini 3 and the
Mavic 3 Classic, including the User Manuals
After you read the Manuals, read tehm again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
At DJI Download Center, Learn aboutDJI
Mini 3
www.dji.com
Mavic 3 Classic
www.dji.com
Fly On and Fly Safe…
