New Member from North West England
I have a DJI Mini 3 Pro, and the Fly More Kit, and am looking forward to getting out and using it.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy Droning…
Happy Droning…
Thanks for the welcome, and useful advice. I have watched lots of YouTube videos on my model of drone, and have a lot to learn, but am looking forward to getting out, and flying my drone.
InspectorTom
