In person Drone Instruction
Glad to have just found and joined the group.
And with the Member's Maps, you might be able to someone to give instructions…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in New York, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
If you have a drone, let us know what type and we might be able to hook you up with some great links…
Happy Droning…
Glad to have just found and joined the group. Does anyone know of any one on one in person Drone training in the Long Island NY area ??
Welcome, friend!
I'm way down in Savannah so I can't help you with any training.. I'm sure they'll be a ton of posts offering help later today, tho! Lol.
Good luck and I can't wait to hear about your progress! You found a great spot to get help!
Reactions: Gagey52 and MA2 317
Happy Droning…
No info populates when I click on the Member Map. I’ve tried it on several occasions and get the same thing - nothing! ???
You might check the privacy settings of the browser?
I use Google Chrome on my PC and the Google app on my phone.
Other browsers may have a different setup. 🤔
You're on the map.
Will do. Thanks.
Welcome to the forum. We look forward to your participation and your view of the world.
Happy Droning…
@LoudThunder This really should be pinned as a must read for all new pilots. Kudos for your excellent and detailed advice. <blush>Misspelled ‘Thunder’ while awaiting my reply to be ‘approved’ by the higher ups.</blush>
Welcome to the forum for sunny socal.
Lots of good instruction on the forum. Drones actually fly themselves, and they even land perfectly. You just have to guide them and keep them away for other objects including persons. find an open area and you'll be fine. You could start it and shut it down a few times. Make sure to always remove the gimble cover. It's very easy to forget. I tape a red piece of cloth on mine. Have fun.
engmarceloacs
