I use a sheet of vinyl 1M x 1M when at or near the beach. On the boat it is hand catch for obvious reasons. Leg extensions - yes, they are small and detach. Oh btw, I have a Mavic Pro.Good morning everyone - I just got my Mavic air yesterday - does anyone use or recommend the landing pads or leg extensions? Are they a gimic or actually useful ? I have a spark and have never used either. Thank you for the input and have a good day
Aaron
I agree I also use both, the Pgytech work just fine.A lot of Undercarriage haters here but if I have to emergency land my MPP on the beach the cameras and whole body will settle in the soft salty sand so i use them in sandy or wet areas for that reason alone.
I also use the folding pads all the time for normal takeoff and landing to cut down on the amount of micro dust being thrown up on takeoff/landing which is then sucked in by the internal fan.
Big landing legs create a bit of extra profile drag and area drag but you can buy minimal Skids like these that will not affect performance, are fold-able clip on/off easily, and weigh only 12 grams.
this design does not affect the VPS like some do.
Gizcam foldable ABS drone landing gear leg holder bracket RC drone accessories for DJI MAVIC PRO-in Drone Accessories Kits from Consumer Electronics on Aliexpress.com | Alibaba Group
I ended up getting both the leg extensions ... and a landing pad.
I have 2 types ofPersonally, I don't like leg extensions. I'm sure they work but IMO, you'll run into situations where the legs just won't be long enough or protect you drone from certain situations, so I bought a Hoodman Landing Pad.
There are several reasons I prefer a landing pad over leg extension;
On the downside, yes, its something extra you have to carry with you. It doesn't make "EVERY" location a perfect take off or landing area, and some can be expensive when compared to leg extensions.
- Depending on the leg extensions you use, you may have to remove them before folding the arms
- With leg extensions on, your Mavic Air may not fit in the case without first removing them
- Leg extensions can raise the drone up some, but its a fixed length therefore tall grass can still get in the way. With a Landing pad, it presses down on the grass making a level (reasonably) platform to take off and land from
- Landing pads can protect you drone from dust and sand (depending on the landing pad size you use) as you take off or land
- A Landing Pad will "somewhat" level a rough take-off and landing area
YMMV....
depends where you fly from. If you are on a beach or dirt you need a landing pad. If the terrain is uneven or you take off and land in grass then you need leg extensions. Both are not too expensive and seem to work very well and Travel too.Good morning everyone - I just got my Mavic air yesterday - does anyone use or recommend the landing pads or leg extensions? Are they a gimic or actually useful ? I have a spark and have never used either. Thank you for the input and have a good day
Aaron
I agree!!!Agree with your post the landing pad makes a difference and on a personal note it lets me know how effective the return to home is on my Air. I marvel at how often it lands on the same spot it took off. I set the pad in a snow covered area surrounded by Forrest. I flew it up over the Campsie Glen in Scotland and as soon as it left line of sight I hit the home button. You know these moments with a tree line surrounding me I saw its return position 200 feet above me and I thought it is perfectly hovering. It landed on the pad within an inch of its departure point. I admit sometimes if there is a slight wind I tend to take over but the landing pad has a second purpose of helping me navigate with it's big bright blue circles.
