- Joined
- Feb 7, 2017
- Messages
- 5,270
- Reactions
- 2,206
Here's what I'm talking about. View attachment 10575
Yes. I keep my ND8 on all the time, and go to the ND16 on super bright days and open light colored areas like a wheat field. I don't like taking the filter off and on with this small lightweight gimbal.Would a ND filter help?
Wrong. Using all manual settings on my DSLR - I tested it by moving my hand overhead to shade the lens. Same results on my DSLR. The camera does not compensate in Full manual mode.No, I don't think that the difference between your two pictures is due to the presence or absence of a lens hood. More likely something with the exposure settings. Look at these pictures. You have the sun there directly in the field of view of both pictures. How could a lens hood possibly help in this situation? The whole idea behind a lens hood is that it blocks direct light (usually direct sunlight) from hitting your lens. But if the sun is in the field of view of the lens, then it's impossible for a lens hood to block out the direct light from the sun without also blocking out your picture. I dunno what caused the apparent difference between these two images, but it has nothing to do with the lens hood.
I am with you, I leave the nd16 on almost all the time here in Wyoming.Yes. I keep my ND8 on all the time, and go to the ND16 on super bright days and open light colored areas like a wheat field. I don't like taking the filter off and on with this small lightweight gimbal.
Wrong. I tested it by moving my hand overhead to shade the lens. Same results on my DSLR.
The picture I used as an example isn't from my Mavic. It's not sunny right now, so I just got that one off the internet to use as an example. Yes, I know the sun is visible in both photos. I'll find a photo that the sun isn't visible if that will help you to understand.Nope, don't believe your conclusion. You may have changed the automatic exposure settings of the camera by doing that, but that has nothing to do with the function of a lens hood.
Try providing a physical explanation for why a lens hood should make any difference here.
