We've added support for the DJI Smart Controller in our latest update, learn more at https://flylitchi.com/dji-monitors
So I downloaded it and installed it. Seems to very similar to running on an iPad. However I'm having one issue. I'm in Waypoint and I'm not able to rotate it. Gone is the slider for degrees, now you have to punch in a number, I do and the little triangle shape does not move. Any clue?
Is there a reason to use one playstore versus another to get the app? In other words use Amazon or use Google?
Yes, it's a different store.Does this mean we have to buy it again?
You could try seeing if the version you purchased will work if you install the Playstore using the instructions linked below. I don't have Litchi but I've gotten the "patch" to work and, at least, I've gotten some apps to work so far.Does this mean we have to buy it again? I already paid for it on Google play
Certified Aerials LLC - How to Install Google Play Store on DJI Smart Controller
How to Install Google Play Store on the DJI Smart Controllerwww.certifiedaerials.com
Hi
Sorry but I am not recommending to do this
You better spend $22 for app then another
$1500 for new drone in your Litchi will crash
In the middle of the flight
Honest question-I thought if the program crashed the drone would just continue The mission until it completed and then would return to home?
Well, I guess since a person might already own Android Litchi and the Playstore install is FREE, one could try it on a simple mission. Or just take off, up a few feet over a soft or net surface and see how Litchi seems to perform. Check out Litchi's functions first without flying and see if the app crashes or seems stable. I gather the mission is uploaded to the drone so once that's done and started, the drone should just carry out the mission. NORMALLY, can the pilot regain control of the drone and stop the mission and/or load DJI Go and take over? Again, I presume, maybe wrongly, that there are some safe ways to test how things are going. Or, as you suggest, at about $25, just purchase the other version.Hi
The app crashing shouldn't bring the drone down. The Android go4 app used to crash frequently with no downed drones. That being said litchi will either work or it won't. I'd rather sideload the APK if I can pull it from my phone. However I suspect it won't work Which is lame considering Both are Android apps. ?Hi
