You should try FPV Camera!I was wondering what advantages and features they have over each other
It is better than all of the others combined.
It's st: FPV booster.com
Or check it out on the App Store under FPV camera!
How so?
Yes, Battery Low RTH will trigger and bring it home. You could still eff that up if your RTH path is compromised by an obstacle or strong headwinds. But if done properly It will come home just fine.]...Re: Litchi and suicide missions - you might be able to program one, but MP signal/battery level RTH would kick in, right??
@Logger makes some good points, I should have specified I'm using iOS. Also the C1 and C2 customization is very good as well since it does both a short and long press, so essentially giving four options.
Ok lets do some pros and cons
Litch:
Pros: Superior mission planning and waypoint execution, panoramic, VR, screen recording, customizable C1 and C2 buttons, and also auto syncs with healthy drones.
Cons: Lack of good active track features, C1 and C2 options are missing one and possibly more options that are in DJI GO app (like center metering), Can be misused by user and program the drone to go beyond it safety limits.
DJI Go 4 App:
Pros: Active track and submenus, gesture mode, latest options for drones (like inspire 2), and overall more stable
Cons: Lack of advanced automation features like panoramic and highly advanced waypoints. Also no direct sync option for Healthy Drones (although you can get another app to do it)
A good note on healthy drones is that it keeps great records of you flights if you sync to it. I use it to analyze my flight and also export the data in case I want to overlay the information on my videos.
I was wondering the same thing.
I did some research on the above link and most of the topics seem outdated as Litchi and GO have improved over the years.
Perhaps it would be worthwhile to start a new discussion for the same already discussed topic in order to get an updated response from the experience people.
I don't find it so, never had a single issue with it. You can't make a statement of fact based on your own bad experience.DJO Go4 is very unstable on Android. Not to fly with.
You're right.I don't find it so, never had a single issue with it. You can't make a statement of fact based on your own bad experience.
