Im new to Litchi and looking to see if there is a way to fly an orbit mission and have the camera stay pointed and focused on a building in the center of the camera. Any good way to learn how to use Litchi?
Exactly! Try and make sure that you assign a low height to the POI so that the camera will focus at a proper angle. I think the default that Lichti uses for a new POI is 2 meters which usually works well.
You can also use the Mission Hub to pre-plan your flight and then synchronize with the device that you will be using to fly the mission.
Did you save your mission to the Mission Hub and make it public? I want to check out your flight route.
You can also take the video (if one was produced) and upload to Youtube and post a link to the Mission so that others who use the Mission Hub can see the route and then the resultant video.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
