Lost my DJI Mavic pro on my first flight [ DRONE FOUND]
absolutely not funny,i can only imagine how you feel,for some of us this is a once in a lifetime purchase
Great comment, reminds us how abruptly this awesome hobby could end for some of the members on here - got me to thinking - feasibility of the members on here agreeing to fund the replacement of aircraft as essentially an MP Pilots internal crowd funding thing? Thoughts anyone? Would be subject to parameters like trying warranty first, uploading logs etc. to establish reasonable care was taken, and even if a percentage of the replacement cost was covered would help keep people flying. I know I'd be happy to contribute to help someone back into the air and would be great to have some support if my bird is ever lost. I guess it may be too hard, but maybe someone on here knows a bit more about that type of thing?
Your drone completely malfunctioned by the looks of it. I'm seeing a mess of errors I've never ever seen before. Your compass failed, your drone seemed unable to turn, and the IMU lost calibration. This log alone should be sent to DJI and they should warranty you a new one.
I'm curious! The only thing I can see wrong here is the aircraft in ATTI mode despite having 18 satellites. Please tell me how you deduce the other things, thanks.
My brand new Platinum also entered ATTI mode on its first flight while half a mile away but fortunately I was able to get it back as I have experience with RC helis but it was a close call. Since then I've updated firmware and the issue hasn't repeated, however I don't trust it.
Reactions: Philbek
If you power down the TX while in ATTI mode, will the MP autoland?
It will auto land 3 seconds after the remote controller signal disconnects if either "Return-to-Home" (the default setting) or "Landing" are selected in the following setting in DJI GO:
am new to the forum and drones but took my 14 th flight today and so far I love it.
Welcome to the forum!
So, you want to start up your own drone insurance company? But, without worrying about paying out money once all of the stored up cash has been handed out. It's an interesting idea, but it would probably be too time consuming to manage unless you're able to turn it into a full-time career.
So the emergency response in a fly-away may be to power down the RC to force RTH or Landing. I’ve had to do this because of very flakey iPhone to RC connection droppng midflight and not wanting to reconnect. Make sure your RTH altitude is high enough to clear trees and structures. Once it’s back close enough for easy visual flight you can turn the RC back on to hopefully resume flight control or just let it autoland. My MP has been horrible at staying connected with both Go4 and Litchi. Go4 freezes and I have to Swipe shut it down and relaunch. I started on an iPhone 7 Plus and now have an X and the problem is about the same and i’ve used different Lightning cables.
My only other thought is the OP probably should not make a maiden flight in 27mph wind conditions if that was the case. That seems like a huge red flag.
[QUOTE = "Govorin, post: 365666, member: 45890"] Hola a todos, ¡feliz año nuevo ante todo a todos ustedes! Acabo de leer tantos hilos, miré millones de videos, tengo un problema. Perdí mi dron hoy en mi primer vuelo, antes de Año Nuevo:REmuy triste. Vi tantos tutoriales en YouTube, actualicé mi dron al último firmware, lo compré hoy y quise probarlo afuera en un área abierta, donde hay suficiente espacio. Tenía una buena señal de GPS, decía que estaba lista para funcionar, así que subí como 3 m de altura y de repente cambié al modo Atti y comencé a volar lejos, tan lejos que no puedo verlo, y muestra en mi control remoto del RC que el avión está desconectado Revisé mis registros, ni siquiera muestra dónde estaba su ruta ... Pero traté de usar "encontrar mi dron" y probablemente solo muestra la ubicación de mis drones donde pierde la señal, así que fui allí y no lo hice encontrarlo, se pone oscuro rápidamente y me fui a casa .. Así que ahora estoy celebrando el año nuevo tan feliz perdí mi avión no tripulado:( :REy realmente no sé qué hacer, iré una vez más mañana al mismo lugar donde se perdió la señal la última vez, pero después de leer tanto en este foro, y perdí mi motivación, lo encontraré .. Porque algunas personas dicen que cuando el dron vuela así en el modo atti, se mantiene a la deriva con el viento hasta que la batería muere ... Así que no tengo idea de lo que puedo hacer ... Trataré de ir a la policía también mañana y Trataré de llamar al soporte de dji. Tengo mi plan de actualización de dji también ... Y también compramos este dron para nuestras vacaciones. Ya vamos a Bali el 11 de enero, así que no tengo idea de qué hacer realmente ahora. Gracias a todos por su tiempo leyendo toda esta historia :)) y con suerte recibiré un buen consejo sobre qué puedo hacer en esta situación. [/ QUOTE]
Amigo, creéme que lamento lo que te pasó. No tengo ni idea de como puedes encontarlo. No obstante, yo lo primero que haría sería ponerme en contacto con el soporte de DJI y verás como tienes suerte y lo encuentras.
Ahora, quiero hacer una reflexion en alto. Todos pagamos unos precios muy alto por el Drone (sea la marca que sea) entiendo que lo que realmente estamos pagando es precisamente por su I+D (Investigación y Desarrollo) puesto que lo que son los materiales su valor no es nunca mas de un 20%. Dicho esto. Creo que en este caso DJI tiene que buscarte y DARTE una solución. Estamos en un comercio desproporcionado y sin control, a expensas siempre de lo que marcan los fabricantes quienes a su vez nos utilizan de conejillos de indias para avanzar en sus nuevos modelos. Si partimos de la base de que existe un "obsolescencia programada" el resto de conclusiones sobra. Salvo una: "Cuando compres un Drone, piensa que es como si entraras en un Casino. Gasta solo lo que no te importaría perder en los juegos de azar".
Queramos o no...esto es un juego y los aficionados no dejamos de ser una especie de medio LudopatasDroneros.
Repito, te deseo mucha suerte y confío que el soporte de DJI, te diga como encontrar tu Drone o en caso contrario encuentre una solución a lo que te pasó.
CyberPower. Solo gracias a personas como vosotros. Aquellos que como un servidor, tiene escasos conocimientos, haceis posible que sigamos con ilusión este bonito Juego-Deporte. ¡Muchas gracias¡¡¡¡
If you are in ATTI mode then I would not recommend powering off the RC because you will lose telemetry, and you want position data for as long as possible. A better strategy is simply to apply full down throttle to force it to the ground or to manually select RTH, which becomes autoland in ATTI mode.
The log indicates that the compass, and the IMU failed. GPS lock or not, it can't hold position like that, so it switched to ATTI mode.
If you want the Mavic to land, then it would be better to initiate the auto landing procedure from the icon on left side of DJI GO.
While turning off the remote controller would probably be okay in many cases, it would not be a good idea if the Mavic has a good GPS connection and is drifting away in a strong wind. If you turn off the remote controller at that point, RTH would be initiated (using the default Remote Controller Signal Lost setting) and the Mavic would continue to drift away with the wind until the battery reaches the critically low level (causing the Mavic to auto land).
msinger / mBudWalker,
Thanks for your input.
Just checked the Tab S2 and the file 18-01-01-09-39-53-FLY122.DAT is the only file for that date - 18-01-01.
Yea, I noticed that CsvView shows fewer sigPlayers available for these .dat files than for the Mavic .dat files. Still, it would be nice if CsvView could read these files.
I wonder. Is this a CsvView issue or a Go4 issue.
Thanks again.
Check out CsvView 3.2.0.You'll need to tell it to accept an invalid DatHeader.
ryanhafeman
