M2S Recharging Cable / Plug (vs M2PRO)
GMAN007
I plan to purchase a Mavic Air 2S (main reason because of smaller size). Can anyone answer my question whether the battery connection plugs (recharging) are the same (compatible) with the Mavic 2 Pro ? Thanks !
Unfortunately, they are not. I bought this charger: Amazon.com: Powerextra Air 2S, Mavic Air 2 Battery Charger, 6 in 1 Rapid Intelligent Multi Charger Hub (Charge 4 Batteries Simultaneously & 2 USB Ports) Compatible with DJI Mavic Air 2 Drone (Not Fit Mavic Air 1): Electronics, It'll charge four Air 2/Air 2s batteries at a time, as well as the controller.
Reactions: GMAN007
Thank you for the detailed reply / answer. I was trying to figure out if anything could be shared between the MA2S and M2PRO.
Trubbaman
