M3T just didn´t move
JCDiaz
Bogota, Colombia
A couple of days ago, after a waypoint mission got to its last point it was supposed to RTH. Well...it did not.
Although I did not loose signal, the drone just freezed for at least 5 seconds. I tried to elevate it, descend it, move it...and it just did nothing.
After the 5 seconds (which seemed as hours), I controled the drone again.
Flying with Pilot 2
Any ideas?
@JCDiaz ,the delay you experienced was probably just the drone itself, going through the procedure of setting up the parameters for its return journey ,back to its start point
all you can try, is to do a similar mission and see if it happens again
I have flown about 30 missions with my 3T without any issue or glitches that I have noticed, but I usually set to "Hover" after missions and manually bring it in.
Michael Greece
