I had a similar problem about a month ago. I have sent my machine to DJI for data analysis. Waiting for the results.Hello,
Today i was flying with my mavic, and suddenly, all motors stopped, and it drop from the sky (40m heigh). I was pushing both stick forward before it dropped. Battery was 79%, 12 gps, gps mode, 40 m height, 85m away and full in my sight. Just before it touched the ground, all the motors turned back on, but it was too late and now my mavic is completly destroyed. Can you tell me what happend ?
No, both stick were up !I think you probably activated both stick (see remote controller urgent stop mode)to emergency stop the motor ..
@smh , I've added your incident to my list of similar ones. It seemed like these power loss issues had pretty much gone away, but it looks like there is still an issue. Your Mavic was built a little more recently than the others on my list, which is a little worrying. Would you mind also trying to find the build date of the battery? It's one data point I hadn't started tracking at the beginning, but it could be worth noting.
One thing that seems to be unique about your incident is that you observed the motors start up again. Also, did I understand correctly that the front LEDs remained lit the whole time, even when the motors were stopped and the Mavic was falling? I've never heard anyone report that before, either.
BTW, here's the link to the data I'm collecting:
Mavic Power Failures - Airtable
For me, this is unacceptable. Do you really think that I'm the only one who is doing that ? For sure every Mavic owner has at one time pushed both stick up at the same time. In my opinion, that's not a valid reason for a drone to fall out from the sky.Look at post 80, @mig25 said that if you push both sticks all the way up it could cause the mavic to go into over discharge protection and drop out of the sky
Sounds like nonsense to me. Who is this supposed to be protecting? Battery? By making it fall from the sky along with the rest of the drone. I have once seen a warning flying my p3a full stick up in the cold. Protection send the warning and slowed the drone significantly preventing it to crash due to discharge. If anything this would be a proof that it didn't kick in when it should have.Look at post 80, @mig25 said that if you push both sticks all the way up it could cause the mavic to go into over discharge protection and drop out of the sky
But why the battery is still functionnal then ? If this is some hardware issue, shouldn't the battery be dead ?Do we know that "over discharge protection" means total battery shutdown? Or, that "over discharge protection" applies to currents seen in normal operations? I had a situation where Sport mode, full throttle resulted in a battery warning to be displayed in the Go App. The battery output was then limited, not cut off.
I've speculated that there may be safety circuitry that will cause a total shutdown in a situation where a battery fire or explosion is likely. E.g., the battery contacts are accidentally shorted. Maybe that's what is meant by "over discharge protection". A defect in that circuitry could then cause these total shutdowns.
I'm just speculating. I don't actually know. Maybe the overload detection circuitry is based on a temp sensor.But why the battery is still functionnal then ? If this is some hardware issue, shouldn't the battery be dead ?
Waiting for news. Really scary story. Mine is coming in a very few days, first drone ever. Reading all I can about it.
I have yet to fly my Mavic and it is stories like these that really frighten me. As it is, my bride thinks I'm nuts. If a crash that were to happen to me, I would never hear the end of it !!!
I am seeing a bunch of posts on several forms of the same thing, drones dropping out of the sky, I am at the point I am not sure they are safe to fly anymore
