Mavic flew away in Ghent Belgium
koplinedge
USA
My Mavic pro platinum flew away in Ghent Belgium but i end up tracking it with the video cache files, i got a image of the drone landing. i found the location and coordinates with google earth and i went and scope all the perimeter but no luck someone grabbed it at landing for sure... now the questions is if there is a site where i can look for lost or missing drones like a lost and found sort of thing where lost drones will get reported?
anyone... anyone?
There is a lost and found forum here.
I hope you tagged your drone with return information. Best of luck
Unfortunately i didn't, after i flew it in the andes of Peru with heavy winds on remote locations never thought this could happened in a city surrounded with satellites but in this case was because magnetic interference.
There are no more navigation satellites available in the city than there are in the Andes.
The G in GPS stands for Global.
w
We know the situation very well at that place. The restaurant on the corner of "Burgstraat and Gewad" calls "De Gekroonde Hoofden", and the deceased owner, was a friend. We see that your drone has landed behind the restaurant, on one of the roofs, or in one of the little gardens ??? Hard to see or determine! You have taken off on the small bridge against the castle “Gravensteen”, which can be seen on a print of your map.
Google Earth
#googleearth
I will ask for you the question in Dutch for you, with the question if someone living close to the "Gravensteen in Ghent, Burgstraat corner" The Gekroonde Hoofden "and the Gewad, has found a DJI Mavic Pro?
Voor de Gentenaars!!! Heeft iemand woonachtig dichtbij bij het “Gravensteen in Gent, Burgstraat hoek “De Gekroonde Hoofden“ en het Gewad, een DRONE DJI Mavic Pro gevonden ???
There was a similar lost drone post I just replied to, the same advice might be good to try here with your lost drone.
Possibly found by one of the residents.
Do the door knock asap, maybe a quick leaflet with a photo of your (or other) M1P, and a note of small reward if you like, may get some local kids out searching their yards.
You might only need to do 5 or 6 homes / businesses, knock on each door and present your case nicely, hand them a leaflet, and hope you get a call eventually.
Good luck.
birdevyview
