Mavic is rotating while hovering.
Got it. As far as I know, if it actually rotates, then either the wind is way too strong, or the IMU calibration is way off. At least that's what I've seen so far.
Well once I calibrated everything and swapped blades it’s seem to solve the rotating problem anyway so. I’m happy about that. I’ll try that other thing you mentioned to fix the camera pan.
have same issue.
performed all of the same maintenance as other pilots have
same issue.
have noticed that in the app under
MAIN CONTROLLER SETTINGs > ADVANCED SETTINGS > EXP
The Rudder monitor is showing a slightly off center dot. It will go to center, but once you touch the left stick and let go it has a slight +x and +y off center.
anyone else see it like this.
aodgizmo
