That flight doesn't have any speed above 14.4 mph and you would expect more on that flight path.Here is my flight log. I am flying at an AMA field were I do all of my test n tune. I was just flying around to get the feel of the MP after I set my EXP and YAW rates the way I have on my P4P
What do you see causing the issue?
There's no immediate cause showing up.
Did you fly before changing exp and yaw settings to see how it flew with stock settings?
I'm not sure how your changes might have slowed the drone but I'd be looking at putting it back to defaults and checking to either confirm or eliminate that from suspicion.
And if you do more speed testing, a straight line with an out and back flight would probably be better
If the drone won't fly faster than 14 mph, something is quite wrong.98% of my flying is inspections, so slow is good. But I couldn't get out n back with a little wind like I had in my flight log above
The flight data indicates that Obstacle Avoidance was disabled so that is eliminated from the suspect list.Whats all the fus about yes when the sensors are on with the mavic pro they reach a speed of 13 mph ..... to get max speed just turn them off
Mavic Pro - Sport mode - 40 MPH sideways keeping up with cars:
If you're only getting 13 MPH, then your Mavic isn't working right. Mine does 24 - 25 MPH in P and over 40 MPH in Sport mode. I can't see turning off the sensors unless you like bashing into stuff head on at 40 MPH.
What was wrong with it?Whoop, whoop speed issue is fixed. I am hitting 19.8 to 20.1mph P mode. Thats a 33% increase from where I was.
Still slower than some have posted. I have looked at tons of Mav vids and logs over the past few days. All have been right at 20mph. If you are claiming faster... it didn't happen.... without flight logs (tail winds don't count)
