Think i answer my own question. looks like they attach on here?
DJI Mavic Pro landing skid / raiser by NoeI
That is unfortunate i think i remember him posting his original frame with the landing loops and people jumping all over him. Its a shame in that we are just posting about ideas and well none perfect they can be perfected by everyone's input and suggestions. I like the Idea and maybe when i am down in Tampa i can buy lunch and have my bother print these out. He owns a large 3d printing company Engineering & Manufacturing Services | Florida 3D Printing & 3D ScanningYes. They attach to that frame!
The creator (who lives next door to me) did not test it flying nor floating wise, so use at your own risk!
Noel (ex user Guest here) is open for suggestions.
He does not want to come on this forum anymore, so if you have any suggestions you should post it there.
Took another flight with them on in sunny warm Michigan. Ya right. Overcast around 25 degrees with light wind. I setup the osmo and GoPro to film. Not sure if anyone has used this but I was setting up The Autopilot app with their Autoframe app for the osmo. If you use the Airframe app to connect them the osmo will follow the quad. Well after a half in hour out in the cold I couldn't get them to all connect. Only thing I was successful at was draining the battery's and getting them cold.
Anyways I used the Litchi osmo app to adjust the camera. A third hand would have been great. Osmo footage in the foreground, GoPro to the left and to the right the camera on the Mavic. Shorted up the footage so the mavic and osmo footages are a little off. Anyways I am happy with it and they will not get in the shot. Not much of a difference in battery life. They do make it easier to hand catch. You can catch at the front were the blades are higher plus not get near the sensor. Ordered the stuff in black to make a not so bright set.
I am good with it. It suits my needs. Not planning on water landings so I don't think I would need the balls. I think they would get in the camera view. That was the bigges drawback for me on the set I made for the P3. I will be in Florida in about a month so I defently will have them on out over the ocean and intercostal. Then I can see if they effect the battery time. I don't see any loss in flight characteristics and they do not show up in the footages
Very interesting concept. I'm wondering how the floats might disrupt airflow under the props? A fair percentage of the area directly below the prop appears to be blocked by the float. I would think at the very least this would decrease the lift and possibly the stability.Inspired my Matt I created these. First test flight yesterday. All seemed fine, but I had no wind at all. So more testing ahead. Material was 8 Euro (pool noodle and velcro strap).
Thanks all for helping to come up with float solutions for the Mavic. Hopefully someone will succeed in developing a true water landing system other than the big balls version.
For now, I'm just going to use a Getterback for recovery. A recent post showed a great success story after crashing into a lake. This only works well if you fly over water <100 feet, have have DJI Refresh, and that's only for the first year.
A test flight as you've done is the true test. I believe you said all went well so looks like a great recovery system. I don't know if a landing solution would even be possible given the low profile, at least not without getting a little wet or considerably taking away from the Mavics ability to fly well.That would be the laminar flow boundary layer that you are speaking of. Which is at the rotor or props proper. if you had access to NASA's super computer you could test it. My guess it would just wash over the floats just like it washes over the Phantoms arms in the video.
Yes. Noodle is solid enough. No water soaking (that's the idea).are those foam noodles solid? Is there any chance of the strap ripping through the foam?
Those are actually pretty common down here in Austin for our lakes, streams and rivers. The actual "thing", I believe, is called a "Fun Noodle", or that was the original name for them. The solid ones are smaller diameter and fit nicely inside the hole on the bigger ones, proving more flotation--especially for less buoyant swimmers, like the guy below (OMG)!
