Metal rattle on motor
iamdev
Arizona
Hello everyone,
I'm heartbroken as I've just lightly crashed my DJI Mavic Air 2 into a tree. After a 3 foot drop, one motor makes a metallic rattle sound.
The drone gave me a message saying impact, and that I needed to restart the drone.
I've removed the prop, and when I spin the motor with my finger, it sounds metallic, none of other motors sound this way, and the sound started as soon as I restarted the drone.
I've tried using my breath to blow out debris.
The drone still flies fine, but I am scared of a bad bearing that could lock up, or further damaging my drone and would appreciate advice.
sounds like you have a loose magnet that is catching on the stator as it rotates
Reactions: iamdev and Thomas B
Thanks for your response.
I spun it up without the prop to see if the motor shaft was bent. Looks good.
Let it hover and did some movements to observe. All looks good.
I took out my magnifier and inspected, couldn't any significant difference compared to the other rear motor.
I'm still concerned.
  • What is the severity of a loose magnet?
    • Should I not fly anymore until repair?
    • I don't have DJI refresh (wish i did now....)
  • Are there additional steps that I can do to troubleshoot further?
<EDIT> Also forgot to mention, the drone is brand new, I've owned it two days </EDIT>
have you tried to use an air puffer or some canned air to blow through the motor as @Thomas B said could be something in the motor from the crash good luck hope you find the issue
Reactions: iamdev
themirac
