Mini 1 battery info
360 Guy
DELAWARE, USA
The battery in my mini sat for approx. six months.
Installed in the done, turned it on, three lights light out of the four.
Plug in the charger and two hours later still only three lights lite.
Suggestions to bring back to full capacity or bad battery?
TIA
I don't have an answer but have a few questions. What are you charging it in, the mini or a 3 battery Flymore charging hub? What amperage is the ac adapter? Have you tried different USB cables? Do you have another battery to see if your charging setup works? Have you tried a flight with it to see if the led charge level indicators drop?
@PANTHER you could try switching the drone on with the battery in and the RC and screen connected go into the menu and see what the battery info says about the state of charge for each cell
then see if it will actually let the drone take off ,its possible that the BMS has become stuck because of the long hiatus without being charged ,or discharged ,if it does work fly the drone till the battery gets down to about 10 % ,let it cool down then try charging up again
Reactions: EyesWideShut
TIA
Charge the battery overnight.
I have the Mini-1 also...a wonderful little machine!...and I've gotten the sense that the batteries do tend to charge slowly.
Worth a shot...
deepdark
