Mini-2 Batteries in Mini SE
Chaosrider
Carson City, NV, USA
Will Mini-2 batteries work in the Mini-SE?
I think the answer is yes, and I think there was (at least) one previous thread about this, but the forum SW didn't pull it up when I typed in the subject line.
I have 3 Mini-2 Fly More Combos, and hence, 9 batteries. If the Mini-2 batteries work in the Mini-SE, I'll probably pull the trigger and get the SE.
Thx,
TCS
I presume they work since near identical aircraft,just different range if it got 6 pins on the battery I dont see why not
@Chaosrider it all depends on whether or not the shell of the Mini se is the same as the Mini 2 or the original Mini, the original batteries of the Mini will fit in the Mini 2 shell, but not visa versa i know the mini se uses the uprated motors and props of the mini 2 ,but not sure if the shell is the same where the batteries go ,i am sure someone with a mini se should be able to tell you
As I understand the mini mavic se is built with the mini mavic body so they are the same
I think they will work. I think that was well established in some thread on this forum, that I can't now find.
I'm going to wait for a firm confirmation before I pull the trigger.
I hope that happens soon!
Simple search gave this,,,,I guess that's yes then
Ideally, I'd like to hear someone say, "I have used a Mini-2 battery in a Mini SE and it fit and worked fine".
Thx all!
TCS
Did you look in the DJI store? In the UK version dji-mini-se-tm it describes the SE's battery as
DJI Mini 2 Intelligent Flight Battery
DJI Mini 2 Intelligent Flight Battery​
£50
Well, specs are all well and good, but I'm hoping to hear someone say, "I plugged a Mini-2 battery into a Mini-SE, and it fit and worked just fine".
I'm just trying to dodge getting a Mini-SE Fly More, if there even is one. If I can use my Mini-2 batteries in the Mini-SE, then I have no need for the Mini-SE Fly More.
Thx,
TCS
After some searching I find this out,,good read and battery not only 7.7 instead of 7.2 its heavy so goes over the 250gram weight,,,learnt something myself,,,,,,,,just checked my se battery with magnifying glass and both are 7.7volt so I cant try the 7.2 which is what I thought I brought,,only 1 came with drone so brought another and didn't even bother to check
Can you use Mavic Mini’s battery in DJI Mini SE? Screenshot_20220404-122905_Samsung Internet.jpg
Reactions: Gagey52
I have 2 batteries for my Mini SE. One came with the basic kit and I later bought a second Mini 2 battery. Yes the Mini 2 battery works identically in the SE.
The Mini 1 battery also works but it's heavier and produces a bit less flight time.
Thx,
TCS
Those are not specs, they are accessories/parts sold for the SE, the batteries on that DJI page are described as for the Mini 2. So unless DJI put the wrong item on the SE page it means the two drones use the same battery.
Thx all!
TCS
I have Mini 2 and Mini SE, batteries work well in both, however flight distance is reduced on Mini SE due to Wi-Fi.
Reactions: Gagey52
Can you use Mavic Mini’s battery in DJI Mini SE? View attachment 146224
I'm in the USA, and I'm indifferent to the 250g limit. At 5 bucks a pop, I'm happy to register all my drones.
But this isn't quite the battery compatibility that I'm looking to confirm. I want to confirm the the Mini-2 battery (Not the Mini/Mini-1 battery) will work in the Mini-SE.
All my batteries are true-blue DJI.
Thx,
TCS
That's what I wanted to hear!
Both the Mini-SE I just ordered from Amazon, and the used Mini-1 Fly More that I previously ordered from a private party, are now scheduled to arrive Wednesday. These will be added to my existing fleet of three Mini-2s.
This, of course, suggests a new handle...
MM
Thx,
TCS
Who mention mini one ? Are they the same ,well I dont fn know,was just trying and learning but now I dont give a hoot what you buy,
I started to use the name Mini-1 for the Mini to avoid ambiguity (while creating a bit on the edge). "Mini" is sort of a generic term, or can sound that way. It's a better term for the class, than for individual model.
Sorry...didn't mean to be annoying...not sure what I said that was.
Thx,
TCS
Thx,
TCS
No sir you have done nothing and I deeply apologize to yourself and other forum users
Mental illness gives me good and very bad days and I lost the plot before I even logged in
I have much respect for my elders and feel pretty bad today ,,sorry
I'll go sit in the corner
Reactions: Gagey52
Thx,
TCS
Just saw this... @Chaosrider, you do not need to get a new number and pay $5 each time... you only need to do this once, then use the same reg # on all your drones.
And, of course, you don't need to do it at all for any of your <250g drones.
So I have the Mini SE Fly More Combo, but I am planning to get a cheap used Mavic Mini 1 and wondering if the SE batteries will fit in and work properly in the Mini or... ?
NIKLM
