Hello,
Sorry for digging out this ancient thread.
If I buy the Anker prime 27650, it does have output like:
12V - 1.5A (which is 18w?)
And 15V - 3A (45w?)
Total output up to 250w.
Would I be able to draw the Maximum 36w?
Since on 12v, I can't get more amps (i.e. 12v x 3A)
Thanks,
Hello,
And 15V - 3A (45w?)
Thanks,
i think that powerbank can does max 140W per port or 100W+140W for the 2 usb-c ports
the usb-c ports do power negotiating following the PD3.1 standard.
so it asks what the max voltage is a batterycharger will accept
Hello,
And 15V - 3A (45w?)
Thanks,
PD chargers negotiate which maximum voltage/current can be supplied.
in this case the drone/battery does accept 12V/3A
this does not mean it will charge at 12v/3A
depending on how empty the battery is it will begin on 12v and after a while switches to a lower voltage and current.
also the higher the current, the hotter a battery will get.
i think my M3P batteries charge at around 2.5 ampswhile my charger can do 63 watts)
max charging power is 30watt which is indeed 2.5 amps at 12v
tocotco80
