Missing ability to change video codec and film mode on mavic air 2
bluemax3000
sydney
Hi all,
Have a mavic air 2 and have been using it for a bit now suddenly I can no longer change the codec or video mode.
It is not visable in the memory. Upgraded IOS APP AND FIRMWARE and still problem exists
Any thoughts?
If you shoot in 4K/60fps, you can only shoot in H.265. Even if you return to a lower frame rate, it will still be in H.265 until you go back into the menu and change it back. It would be nice if it would default to H.264 on everything except 4K/60 then go back to H.264 when you switch back to a lower frame rate but it doesn't. That's my only thought, if you are shooting at a lower frame rate, you should be able to change the settings. You are connected to the aircraft when attempting to change the settings right? It only will allow you to change that kind of thing when the aircraft is on and connected.
Reactions: eEridani
Hopefully the OP will reply to the suggestion above..to help others with same.
Trubbaman
