Mute the controller?
plrogers1126
Is there any way to mute three controller? I tried my first facebook live broadcast and it worked like a charm but the chirping from auto focus and Low Battery warning was awful.
Well.... sort of. I'd really like the option of maybe led's instead of an annoying beeping...
:p check this out...
Those LEDs are a 180 on the beeping!
It needs a firmware upgrade so that the beeping can be silenced in an intelligent manor. Aquarium controllers beep pretty loudly when something is wrong. If you hit the silence button it stops for a period of time but it will come back faster if the situation is getting worst. DJI could implement a similar subroutine and also a toggle to turn off certain non essential sounds like the auto focus.
For Critical stuff use subroutines like
If Battery Low + drone going further Then more beeping
If Battery Low AND drone getting closer Then No more beeping
Simple intelligent commands like that could make the experience a lot less annoying.
An intelligent solution would be nice but as a new pilot I appreciate the feature. It would be easy to forget your running low on juice and get in trouble.
tflys78
