New drone pilot, Sarasota ,fl
I am interested in joining anyone or group to fly together and learn more about this hobby
Even though you are an experienced R/C pilot, Drones are trerated differently…. As a New Drone Pilot, there are a couple of Legal Things you may need to do…
I read that yoyu have a Mini and if you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs less than 250-grams (0.55 pounds) and if you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot. I have now passed my Part 107 License Exam and am awaiting the arrival of my Permanent License and then I will re-register my Mini 2 under Part 107.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Florida, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini, including the User Manual.
Happy Droning…
Thank you Lee for the invitation, but what I looking forward is the freedom of going around the county to fly and take pictures.
Funny, Lee is offering you exactly what you asked for, "I am interested in joining anyone or group to fly together and learn more about this hobby"
Don't look a Gift Horse in the Mouth...
can you fly drones at CELREY FIELDS sarasota fla. legally
It all depends on where you want to fly, You might need FAA Authorization to fly in the Sarasota-Bradenton Airport Class C Airspace (which had some strict Altitude restrictions…).
But I think you are in the clear, but it's all on you, as this is only my opinion as I checked DroneUp and it looks like you are in Class G…
But use your copy of B4UFly to check…
Reactions: wjkrysak
AVI Drones
