I’m new to drone flying I just got the
DJI mini 2 with fly more kit 2 weeks ago.
mavicpilots.com
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
According to CAA, drones are allowed in the UK, subject to CAA regulations. Read on for more details.
drone-laws.com
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
I also have a
Mini 2 and I hope your new baby has many long flights across the Highlands. Below is the link to all of the downloads offered by DJI for the
Mini 2, including the User Manual.
At DJI Download Center, Learn aboutDJI
Mini 2
www.dji.com
Happy Droning…
