New guy
Hello from the Crossroads of America groggysbird.
Always room for another Hoosier. 👍
Welcome to the Forum. :cool:
Welcome to the forum! :)
A few useful things to get you started:
Thanks that will help me out a lot
Welcome to the forum from the beautiful woods of Maine! There’s many knowledgeable members willing to help you with any questions you have. Search the forum using keywords and if you don’t find an answer post your questions and I’m sure you’ll get a quick response! Fly safe and stay safe!
Hi all just joined got Mini 4 pro and learning about it,
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying with the small battry and under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Indiana, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
ryanhafeman
