New Mavic pilot in the DFW area
Skorch
Texas
Hello everybody! I recently purchased a used Mavic Air 2 and am excited to get flying. I got my 107 license last year and have previously flown fixed wing drones for the military. Looking forward to learning from the more experience pilots on here and sharing my successes and failures with others. See you in the skies!
Hello from the Crossroads of America Skorch.
Thanks for your service. :)
Welcome to the Forum. :cool:
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching .👍👍
Welcome from the Hampton Roads area of Virginia, USA. I am a Mini 2 Flyer and I know the excitement of flight. So, if I may offer some advice.
Here are a couple of Legal Things you need to do… Register your Drone, that can be done at the FAA Web Site. You also need to get your TRUST Certificate (Does your Part 107 replace the requirement for the TRUST, I think not... You can get that at the Pilot Institute We Site (FREE…) .
FAADroneZone
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Below is the link to all of the downloads offered by DJI for the Mavic Air 2. You will also find the 57-page User Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
https://dl.djicdn.com/downloads/Mavic_Air_2/Mavic_Air_2_User_Manual_v1.6_enIII.pdf
Happy and Safe Droning…
Welcome to the forum! :)
Greetings from Birmingham Alabama, welcome to the forum!
Hello from Minnesota and welcome to the Forum....congratulations on your Mavic Air 2....There's a lot of good quality teaching/feedback going on in here. Just ask, and the experts are great on providing good sound advice for you to apply and use... Remember to always Fly safe, Fly Smart and keep the drone in sight.
Welcome to the forum from the mountains of Colorado! Happy and safe flying!
bullet_magnet
