New member from Chardon Ohio
dragonrider
Chardon, Ohio
Had a Spark about 3 years ago. A year ago I took off and went up to 150 feet and got the error message that I lost voltage and it came down without power. It was not even worth thinking about repair. I recently bought a MA2 fly more combo and loving it.
Happy to be flying again!
Dragonrider
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching
and stay safe.. Thumbswayup
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
If you are in the U.S.A. there are a couple of Legal Things you need to do… Register your Drone; that can be done at the FAA Web Site. You also need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) .
FAADroneZone
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Below is the link to all of the downloads offered by DJI for the Mavic Air 2. You will also find the 57-page User Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
https://dl.djicdn.com/downloads/Mavic_Air_2/Mavic_Air_2_User_Manual_v1.6_enIII.pdf
Happy and Safe Droning…
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum! :)
Reactions: Skywatcher2001
Welcome to the forum from Chicago the Windy City.
I also own the MM2, I like flying that,rather then the MP.
Welcome to the forum from south central Florida :cool: and enjoy. 🌴
LizP
