New mini 2 pilot in San Antonio, TX
SanAntonPilot
San Antonio, TX, USA
Hi everyone. I’m brand new to drone piloting. I’m in San Antonio (Stone Oak area) and looking for safe and legal areas to fly my Mavic Mini 2. Found a few areas simply by doing Google searches but want to see where everyone flies recreationally. I have already registered my drone and have my TRUST certificate. Just looking for ideas on where to fly. Thanks!
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
It's great that you have already taken the FAAs TRUST and registered your drone.
I also fly the Mini 2 and I registered my Drone because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot. I recently passed my Part 7 Exam and when I receive my License (the TSA has to investigate every applicate and it takes 6-8 weeks or more…) and I'll re-register my Mini 2 under part 107…
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Since you are new to Drones, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy Droning…
I am in San Antonio. I fly all the time in the SA area and outside of it. Fly where ever you want as long it s legal. I use Airspacelink but lots of folks use other LAANC approval sites. Just make sure you are using a LAANC authorization app to make sure where you can fly and what altitude.
Authorization is pretty fast (almost immediate in most situations). Once you get use to the process it takes only a few minutes to make sure you are good to go.
I request authorization every other day LOL. Whether I am going to fly or not. That way of something happens or I want to do a quick flight I can just get off the ground and fly.
Welcome
Welcome to the forum! :)
Greetings from Colorado 🇺🇸, welcome to the forum🎄
bmo4
