New Pilot from Melbourne
Since you live Down Under, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3, including the User Manual.
Fly On and Fly Safe…
Champion
Welcome! I'm new here as well and still learning a lot from the experienced folk here onsite. I'm also a long time photographer and wanted to expand my photo capabilities. After seeing drone videos and checking on the specs, I was pleasantly surprised at all the built in safety features, the range and the flight times - and now, the fantastic smooth 4K video and still shots.
Your drone should provide plenty of new challenges and views no new lens can get - looking forward to seeing some of your "sights" from your part of the world.
Thanks and yes, I think a long time in photography is a great place to start (M2CW...) as a very new pilot.
I am blown away by just how good the video is from this unit.
Reactions: wjkrysak
InspectorTom
