Released today...
FAA Highlights Changes for Recreational Drones
Here is the "UnDigested" version so you can read exactly how it's worded in the Registry:
Highlights:
Recreational flying in controlled airspace now restricted to established flying sites. Altitude caps in accordance with UASFM maps.
LAANC for recreation later this summer. Same altitude restrictions on UASFM after that.
400-foot cap in Class G airspace, no further authorization needed regardless of distance from airports.
No fixed sites within 2 miles of closest runway point in controlled airspace unless approved by the FAA. Less than 200 currently noted in the US (193 actually).
That was the implication of the leaked memo, so not surprising that it turned out to be the case. It will be interesting to see how the recreational implementation of LAANC works, and how long that takes, but it's a serious restriction on recreational pilots in the meantime. Longer term, I have no idea how the bulk of recreational pilots, as opposed to the relatively knowledgeable set who frequent these forums, are ever going to adapt to the implementation of both mandatory testing (even if it's online) and airspace authorization.
I think in the meantime, what will happen is that recreational flyers will either 1) ignore the law and fly within controlled airspace anyways, 2) will still contact ATC who will tell them to stop calling, which will eventually lead to 1, 3) they'll start contacting their elected official to tell the FAA to get LAANC for recreational finished, which will be so few people that it won't be sped up anyways, or 4) they'll stop flying altogether.That was the implication of the leaked memo, so not surprising that it turned out to be the case. It will be interesting to see how the recreational implementation of LAANC works, and how long that takes, but it's a serious restriction on recreational pilots in the meantime. Longer term, I have no idea how the bulk of recreational pilots, as opposed to the relatively knowledgeable set who frequent these forums, are ever going to adapt to the implementation of both mandatory testing (even if it's online) and airspace authorization.
Path of least resistance says it'll be 1 or 4 for most recreational flyers. And that's for the people who will actually be aware of the new rules, which is probably the minority of drone owners. It's amazing to me that the FAA decided to implement this without having recreational LAANC or some other option prepared, outside of the extremely limited fixed flying sites.
If a child lives in a relatively urban OR suburban area of the Northeast, they break the law if they fly their toy drone (under .55 pounds) in their own backyard at a maximum height of 10'. I think you're going to see a lot of reasonable, law abiding drone operators violating this rule.
I'm depressed..........
Peter Tennant
Sar, quick question, as I understand it the LAANC will only apply to recreational pilots who want to fly in controlled airspace, which I have assumed is around airports, military installations and the like. So for most flights shouldn’t things stay the same? Obvivously the FAA is staring no flights above 400 feet and VLOS only so the hobby rules are gone. This seems to be the same as part 107 is.
As for the online testing I hope it’s a reasonable test.
Thanks
Paul C
Also I wonder if DJI will change the max height to 400 feet since it seems 400 is now the limit for all.
Paul C
Highlights:
More bureaucratic [Language Removed by Admin] .. it will all end when we are all flying paper airplanes.
