New user
Welcome to the forum! :)
Good morning everyone..
I have just got back into drones after a few years away from the hobby,my last quad was a TBS Blacksheep Discovery using DJI m v2 .
I have just purchased a dji mini 3 and flymore combo.
I must say i am very impressed so far ...
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you have. Search the forum using key words and if you don’t find an answer, post your question and I’m sure you’ll get a quick response! Fly safe and stay safe!
Welcome to the forum from Len in South Wales
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy Droning…
twixer_bear
