Hello, I am currently living in Northern VA, in the city of Fredericksburg. Just got my first Drone the Mini 3 Pro. Already got my TRUST Cert and will have drone in hand tomorrow
Thank you for the welcome, I canāt waitWelcome to the forum from the outback of Australia. Look forward to your input on the forum, E11Evab.
Regards
Thank youGreetings from Birmingham Alabama, welcome to the forum!
Thank you for the great infoWelcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Members map
mavicpilots.com
Congrats on getting the TRUST Certificate out of the way. Your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREEā¦)
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.trust.pilotinstitute.com
Link to the FAADroneZone (Optional for Drones under 250-Gramsā¦)
FAADroneZone
faadronezone.faa.gov
Since you live in Virginia, there are specific laws and rules for you to follow, please check to ensure these are current.
Drone Laws in Virginia [Updated January 3, 2024]
Drones are allowed in Virginia for recreational and commercial use, subject to FAA and local regulations. Read on for details.drone-laws.com
Now, for some Good Old Fashion Adviceā¦
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its ownā¦). On the Drone, open the front legs, then open the back legs, then remove the Gimbal Cover.
The Gimbal is the most delicate item on the Drone and banging or bumping can damage it. I also fastened a short "Remove Before Flight" ribbon to the cover so it's more noticeable and I do not forget to remove itā¦
Turn on the drone and watch it come to "life." Watching the Gimbal go through its self-check is almost like watching a kitten or puppy opening its eyes for the first timeā¦
Place the drone down (preferably on a Landing Pad) while it finishes its self-test (collecting satellites, etcā¦).
If you go out in a rush and race thru your start up and take off before the drone has finished it prep, it may update its Home Point over that pond or that old tree you are flying over and in your excitement, you'll fly the drone long past it Low Battery point and when it engages Return to Home and lands in the pond or in a tree; it will be all on youā¦
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
After you read the Manual, read it again, you will be surprised what you missed the first time and you will be better prepared for that first "scary momentā¦"
DJI Mini 3 Pro - Download Center - DJI
At DJI Download Center, Learn aboutDJI Mini 3 Prowww.dji.com
Happy, Safe and Legal Droningā¦
