Newbie w ? re 250 grams
t are you planning on tracking? The algorithms are set up for people and cars, boats are a kind of hit and miss depending on how car-like the shape of the boat is etc... The Air 2 will do tracking and you can probably find one for a decent price compared to the newer models. Also it has an SDK released so it will work with some 3rd party software that would allow waypoints (even though it's only virtual sticks). The newer Mavic 3 or Mini 3 Pro do not have SDKs so are limited to the Fly app.
I should know what an SDK is. But could you expand. I too have a MA2 and love it but have not done anything clever with it. Many thanks in advance.
SDK = Software Development Kit.
DJI releases it so third party companies can develop apps. Think Litchi, etc.
Reactions: LoudThunder
hi from the u.k. I transitioned from r/c helos, to drones and went through the process as you are doing, I initially bought the mini, and two weeks later the mini 2, having flown R/C for many years weight and Line of sight, was never a problem, however due to the size and weight of the mini 2, it requires a totally different mind set to its much larger companions.
Welcome to the forum! :)
Besides registration, what other downsides to going above 250 grams ?
Portability maybe? The lack of needing to register it is likely the only real pro here.
Moving from rc helo's to quads and a co-worker let me fly his mini and Air 2.
I'm still deciding whether I should get a Mini 2, mini 3 pro or an Air 2. I know the mini 2 does not have tracking and I'm pretty sure I want that for fishing on a large river. There seems to be many used mini 2's and Air 2 on the market, not so many used Mini 3's.
Thanks, Derek
TRex 500 fbl, TRex 550 stretched to longer tail boom and 600 mm blades, fbl = 7 lb 14 oz. not afraid of weight ;-)
Thanks, Derek
Hi Derek, I have a brand new Mini 2 that I inherited from a neighbor who lost her husband. I don’t need it, because I already have two of them, along with several other drones. I don’t want to sell it, as I would just rather give it to someone who is new to the hobby. It was given to me, so I would like to give it to someone. It’s the basic kit, not the fly-more. I activated it and flew once to make sure that it was good. If you are interested, let me know. I would be glad to answer any questions or questions over the phone. I offered it to someone else, but he obviously thought this was a joke or scam.
Thanks, Derek
Greetings from Colorado, welcome to the forum.
Greetings from Birmingham Alabama USA, welcome to the forum!
Personally, I don't see having to register a drone as a "downside". What are your plans for the drone? Hobbyist, or Part 107 work?
The Air 2s is an all-around great drone that can be used for both hobby and Professional.
Agreed! Although I fly primarily recreationally, I still registered my Mini & got the P-107 certificate anyway just in case a potential "drone request" comes up. But mostly I did to give myself a more broader range to fly whereas you're very limited if not registered/certified. But again, that's just me.
Thank You Very Much M for sending this to me. I appreciate your generosity and all the help.
Derek
Took the PI test, GTG, Registered Air 2 with FAA. Will print decals tomorrow.
I assumed the FCC # was the serial number ??
my battery stand, gets them up on end to allow bottom cooling and lip matched batt. Any ideas what it used to be ?
I own and fly the Mini 2 and I've flown the Mini 3 and the Phantom P4. I have only good things to say about the mini 2. You have received so many complete, full, and informative responses so far, there is nothing I can add, but I will link you up with all the User manuals for the Drones you are considering. Links at the End…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot. I have now passed my Part 107 License Exam and am awaiting the arrival of my Permanent License and then I will re-register my Mini 2 under Part 107.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Oregon, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini, the Mini 2, the Mini3, the Air 2, and for good measure, I've included the Air 2S, including the User Manuals.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Happy Droning…
I've been reading this thread with interest and appreciate the info and links you have provided.
A quick question though if you don't mind?
I have recently bought a mini 3 pro, after crashing my original mini (first model) and breaking its arm (dji care refresh has ran out just over a month ago, so going to have to fix it myself).
Anyway, I have bought the plus batterys in the fly more kit, and as this takes me over the 250g limit do I need to now register the drone with the FAA, and take another test apart from the Trust one? (I did the trust one just over a year ago, but lost my certificate, so I'm assuming I've got to do that again).
Originally from the UK, but currently living in the USA, so I'm unsure of the law differences here.
I would say yes to taking the FAA test , yes to registering it if you r going to fly it at over 250 grams. I hardly doubt anyone in LE would carry a gram scale around with them....... but if you crash it into someone or something, It probably would get weighed ??
Greetings Derek, welcome to the forum from the outback of Australia.
Regards
Thanks Gagey52,
52 being a number I can't forget, it was my laundry number whist on vacation on Paris Island back in '83. Some impressions stay with you ;-)
If you are talking about that item that your batteries appear to be "worshiping" then I would venture a guess that it's a combustion chamber to a gas turbine...
I am not a lawyer and your immigration status is what, a Resident Alien, is not easily discernable by the rules and regulations that we normally operate under.
I have often written directly the Federal Aviation Administration's office that deals directly with Drones, the FAA UAS Support Center. Their email address is below…
[email protected]
But if you were flying legally as a Recreational Pilot using the TRUST Certificate then I guess you are treated just like any none-tourist drone flyer…
But since you lost the certificate and you if you did not save the file or the link the site that you took the training, you will need to take it again. Therefore, let having to take the training again be your penitence for losing the original (Shame, Shame)… Here is a link to get a new one…
And if this if you can fly with a Trust Certificate then you will be required to register your drone since it weighs more than 250 grams.
Here is the FAA's link to Tourists who want to fly drones in the US, but like I wrote earlier, it may not apply to you…
Now, if your Mini 3 was originally registered in the UK, that might make a difference. You need to explain all this in your email the FAA. Don't worry, they are not going to send Immigration and Customs Enforcement (ICE) to kick your door in and check your "papers…"
Reactions: GFields
bullet_magnet
