Newbie
Read up here! Mavic Air 1 Help
However there is much more to learn in our other categories. ;)
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching. Thumbswayup
Welcome to the forum from the beautiful woods of Maine!
Flytpath on YouTube has a good series of videos from unboxing to your first flight that you may want to check out. There’s many knowledgeable members willing to help you with any questions you have. Search the forum using key words and if you don’t find an answer, post your question and I’m sure you’ll get a quick response. Practice in a wide open field and take it slow to begin with. Fly safe and stay safe!
Greetings welcome to the forum!
Welcome to the forum! :)
Where should I go to learn everything I need to know?
Here are some things to help you get started with your Mavic Air:
  • The current Mavic Air manual can be downloaded here (it doesn't come in the box). Other important documents can be found on the Mavic Air downloads page.
  • Check out this getting started guide for some tips not found in the Mavic Air manual.
  • This video covers all the basics of the Mavic Air.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
Colin King
