I am a total newb, looking a buying a Mini Pro 3
mavicpilots.com
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
An updated compilation of Drone laws by country, state, and major cities (with links to the regulators).
drone-laws.com
First bit of advice, learn what your drone is (or will be…), that's a "
Mini 3 Pro…" not a "Mini Pro 3…"
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the
Mini 3 Pro, including the User Manual.
At DJI Download Center, Learn aboutDJI
Mini 3 Pro
www.dji.com
Fly On and Fly Safe…
