Ok Rucy, splain this!
BbqJoe
Arizona
I bought this chip for my A2S on Bezozon. I've used it a number of times, but can't recall if I reformatted in the drone, my computer, or possibly both.
So I loaded in an adaptor, and popped it in the computer this morning. Curious about my usage and space left, I clicked on get info.
This is what I saw:
I would say what you have here is pretty much empty. I just emptied a similar sd card of it's contents without formatting and it showed partial use just not formatted. OH Ricky, ahhhhhh.
Bezozon? Not sure what that is… on Reddit?
Beware of counterfeit SD / uSD cards. I always skip most sellers, even Amazon, and head over to B&H to be sure.
So that’s my explanation: Counterfeit! Maybe it will work for you, maybe it won’t…
It appears that the date on the device that formatted the card is not set correctly. That probably wouldn't be the case if it was formatted in the drone.
Other than that, is there a problem? What's to suggest that it's not functioning normally or is a counterfeit card?
If you aren't having problems with the card, I'd say copy any files you want to keep and reformat the card in the drone and go flying.
Reactions: Rchawks
The card works just fine, I just thought it was weird.
Maybe I should have wrote Amabezo.;)
Reactions: MS Coast and SethB
Inky
