Pilot from Portugal
Hello from the Crossroads of America ricard0g0mes.
Nice to meet you Ricardo. 🤝
Welcome to the Forum. :cool:
Right now, i have a mini 3 pro.
Since you live in Portugal, there are specific laws and rules for you to follow, please check to ensure these are current.
I tried to load your link several time and it failed each time…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum! :)
brokerman
