Quick question on Video and Battery
propflux01
Central Arkansastan
When you install a battery, turn on Drone and controller, set your video settings, and such, does it revert back to the original settings when you swap batteries during a flight? Do you have to go through and redo all your settings simply because you had to swap a battery?
The settings are saved when you power down the drone. They'll be reloaded when you power up again, with the same battery or a different one.
Reactions: Dbez1
No. The settings are saved
Reactions: Dbez1 and sarahb
Not all settings survive a reboot. Manually reset Home Point is not saved, but that is not a video setting. Zero point for elevation is also reset. Best to test yourself for any specific setting. Generally, though, the settings selected for video will survive a reboot.
ryanhafeman
