Ah nice to know.The little pictograms are only referring to locking the whole prop assembly into place on the motors. You do that only once when installing the props. They have nothing to do with the regular flight and storage position.
That's pretty clear isn't it. Not much room for debate there.Check page 7 of the manual "Preparing the Mavic Pto".
Being convinced is not the point here. The point is that unfolding the props manually takes away a potential stress that is avoidable. Anyway you should check your props for damage before flying and unfolding them seems to be a good idea when checking.I'll never be convinced the start up torque and lateral forces would be more than having the quad flying through the air at 40mph and hitting the air brake.
High five to that. Nice videos, thanks.Grandparents gave it to us the first year we were married. 30 years later same carpet but that is part of the reason I can afford a mavic
Professional airplanes pilots have checklists. These lists are boring and repetitive but they are performed on each flight just to be sure! A Mavic is a reliable piece of kit but it can fail. Checking things before a flight is therefore a good idea. 99 times out of a 100 nothing will be amiss. But the one time you find something before flight and you can fix it, it might prevent you from causing injury and/or damage from a 3 pound brick tumbling out of the sky.
So yes the physics say 'no worries' but common sense says 'prevent problems'!
That is a fact yes. And if you rely on the motors to open them you probably did not inspect your props preflight!Within 3 revolutions of props they are open.
