RC Pilot from Illinois
Opi
Geneva, IL, USA
Hello, this is my first post on MavicPilots. I purchased a Mini 3 Pro with the RC controller to replace my old used Phantom 2. I am an AMA member and my new Mini 3 Pro is registered. I have only flown my fixed-wing and multi-rotor drones at AMA sanctioned fields and events up until now. I am looking forward to getting more use out of my Mini 3 Pro than I did with my Phantom 2 and I have a lot to learn about the rules.
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum. Phantom 2 is like an ancestor, lol. Glad to know you upgraded to Mini 3 pro. If you happen to look for a handy case to carry and protect it, check out our MM330 hard case. Enjoy!
I have also flown RC Aircraft and the once nice thing about Quadcopters is that you can stop at anytime, and just let your drone hover there while you open up another can of soda, eat a sandwich, what-have-you, and the drone will just stay there…
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Illinois, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy Droning…
Welcome to the forum! :)
Greetings from NW Indiana. Lots of knowledge people here, and enjoy all the rules and regs flying your drone ! 😏
Welcome
Greetings from down south in Normal, IL. If you only flew your P2 at the AMA fields you are missing out on the fun of flying a drone. I would never fly with fixed wing planes flying around in basic circles. You have some great scenery up there...take advantage of it!
DrDew
