RC Pilot from Illinois
Hello, this is my first post on MavicPilots. I purchased a Mini 3 Pro with the RC controller to replace my old used Phantom 2. I am an AMA member and my new Mini 3 Pro is registered. I have only flown my fixed-wing and multi-rotor drones at AMA sanctioned fields and events up until now. I am looking forward to getting more use out of my Mini 3 Pro than I did with my Phantom 2 and I have a lot to learn about the rules.
Hello from Cambridge, UK
I have also flown RC Aircraft and the once nice thing about Quadcopters is that you can stop at anytime, and just let your drone hover there while you open up another can of soda, eat a sandwich, what-have-you, and the drone will just stay there…
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Illinois, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy Droning…
Thanks for the tips.
Reactions: LoudThunder
Greetings from down south in Normal, IL. If you only flew your P2 at the AMA fields you are missing out on the fun of flying a drone. I would never fly with fixed wing planes flying around in basic circles. You have some great scenery up there...take advantage of it!
I helped my RC friends find their crashed planes in the corn with that old P2. Found a friends lost plane on my third flight with my M3P. I don’t fly the pattern like I do with my fixed wing planes. I do plan on expanding my horizons and flying in more than AMA fields with my M3P. Thanks
RYNOGOD
