Refresh question.
Subliminal87
Pennsylvania
So I’m buying a mini 2 at Best Buy and looking online at buying refresh.
Do I need to do the video verification to buy refresh? Or since it’s brand new it should just be good after entering the serial?
Just register the serial number for Refresh on the drone before flying it.
Thanks, at this link?
Somehow I ended up with two different links that goes to two different pages to do stuff. This one enters the serial, the other page asked for a video.
Video is only necessary if Refresh wasn't bound to the aircraft before it was flown, so they know you didn't buy Refresh after you crashed it!
Reactions: eva2000
Refresh without the video is available for 48 hours after activation. After that, you have to go through the video process.
Reactions: GadgetGuy
I bought my Mini 2 at Costco and the first time I fired it up, as soon as I logged into my DJI account, the App (DJI Fly App) asked if I wanted to buy the Care Refresh, I did with a credit card, and I've used it once, I intend to buy it for the second year too.
I created the DJI Account on the DJI Forum Web Site like you are doing on here on MavicPilots so I had access to their advice, tips, tutorials, videos and so much more…
You will just need an email address and they will ask for a User Name, Pick something Epic! Mine is LoudThunder…
Once that was done (whether you choose to buy or not) the Drone continues with its updates. Of course, that was after I waited about 4-hours for the battery to charge…
Since you are in Pennsylvania, there are a couple of Legal Things you need to do… Register your Drone; that can be done at the FAA Web Site. You also need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) .
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Below is the link to all of the downloads offered by DJI for the Mini 2. You will also find the 75-page User's Manual, in case your Drone did not come with one.
DJI Mini 2 - Download Center - DJI
Happy and Safe Droning…
Why would Pennsylvania require the pilot registering with the FAA while flying a Mini 2? It's exempt from pilot registration, as long as it isn't used commercially.
themirac
