- Joined
- Jun 27, 2017
- Messages
- 35
- Reactions
- 54
- Age
- 59
Wow....this video is sickI think it will compensate.....chk this out.....
I think it will balance the RPM between the front and rear motors, right? But is there any advantage over using all plat props? May be because you are using externals you need to use the regular props? But wouldn't the rear motors will get even hotter with the plats?I've flown with 2 platinum props on the rear and regular peeps on the front. Works well.
Hey everybody:
I bought a complete set of the new low-noise props, but if I needed to replace one of them, I'm assuming I could NOT use one of my old stock propellers, correct? Would have to replace it with another low-noise prop?
Thanks
