Sandisk card, is it fast enough?
jerryss
I was given a 32gb Sandisk card. How can I tell if it will be fast enough for use in a Mavic?
No model number, it's white and says 32gb, there is a 1 under the 32gb, on the right it says Micro SD HC I
thanks in advance.
That's a Class 1 card.
Your ll Be fine.
Your ll Be fine.
Thanks for the quick reply. What "keywords" should I be looking for when buying cards? (sorry I don't know the difference between U1, U3, Class 10, UH3, etc...) I just need a list of thing to look for and things to avoid.
thanks in Advance!
Jerry
I did a couple of tests my recommendation as follows:
a) Get an Extreme card read and write speed are steady on more than 70mbps
b) Speeds for the Extreme PRO are great but a bit more expensive, based on my tests the different in price is not worth it.
c) Get card that at least write 60mbps or more.
magic31
