State parks rule
Gioba59
I live about a mile from a state park, my question is if I take off from my house can I fly over the park?
Depends on your State and the Park. Here in Utah there are virtually no state laws restricting drones other than making flight over Antelope State Park off limits. Why? I have no idea!
Reactions: CJH92474
Check the park using the Airmap application, if it's outlined in red (see attached example) then you shouldn't fly into the air space without permission from the park ranger.
Hi
You need check exactly what your regulations say
For example I am in California
And California regulations say
You cannot start and land your drone in the park areas but it is do not say you cannot fly above parks
So I can stay outside park
Start my drone, fly above park
And lending it outside of the park
With no any problems
I did this many times
Good luck
Reactions: brett8883
In general, technically yes - since the airspace is controlled by the FAA, not the State Park. But you might end up with a legal fight if they try to go after you, even though you will have the law on your side.
See that’s the thing is that States retain the ability to make their own laws under the constitution so I don’t see how if the State Law says you can’t fly over how it being the FAA’s Federal jurisdiction would negate that state law ??. So basically even if it’s ok under federal law you’d still have to check state law.
The states can certainly make laws, but not if they contradict Federal law. So no - that's completely incorrect.
US Code (Federal) trumps all state laws and US Code states only the FAA can regulate airspace.
Also I assume they have jurisdiction about what you do on the ground so unless you are flying your drone from the ground of another state they got ya
State parks don't have any jurisdiction outside of their boundaries. That is, beyond the boundaries of the park itself.
Reactions: Drgnfli and Ranger
But the State has jurisdiction everywhere in that state so unless you are flying your UAV from the ground of another state you are subject to state law on the ground of that state
We are talking about the parks authority... not the States authority.
If there’s no Federal law addressing it then it’s up to the State if they want to. You can’t contradict a law that doesn’t exist
There is the odd thing called the US Constitution that gives people very broad rights. Also, if there is no law against something, you can do it. That is, laws don't really _give_ rights, laws only tell people what they are not allowed to do. That is how laws work.
Reactions: Drgnfli
There’s no Federal law against robbing your neighbors house as long as you live in that same state and don’t sell the goods to someone in another State. I assume you don’t mean to tell me the State doesn’t have the authority to make laws where there is no federal law in which case a State doesn’t have authority to make any laws
Jimwinter
