Tucson Airplane Graveyard
PeRo
Bavaria, Germany
I am planning to visit AZ and Tucson in March. Now wondering whether it is possible to find a launch site suitable for spotting the famous Airplane Graveyard - even at distance. Naturally, there are lots of restricted areas / NFZs around the city and the Davis-Monthan Air Force Base. Any recommendations?
Thanks!
Looking at Google Earth and the FAA SUAS Facility Maps, it appears that the north side of Palo Verde park would give you 200' AGL with a LAANC authorization about 2.8 miles from the nearest airplanes. The controlled area to the east and south around Davis-Montham AFB is all 0' AGL maximums. But the outer edge to the east on S. Irvington Road a little way beyond S. Harrison Road would allow you 400' AGL at a distance of about 2.0 miles from the nearest airplanes, a couple of rows of C-130s with tankers beyond.
Reactions: PeRo
When I visited several years ago, the "Boneyard" is part of Davis-Monthan AFB, therefore you would be flying a drone over an active air force base. Can't see how this could be a good idea under any circumstances.
It's still part of the airbase and tours are no longer available. All but a bit of the southeastern corner of the base and much of the adjacent area is limited to 0' AGL for LAANC authorization. Definitely not a good idea to fly over the base.
Reactions: RMS001 and PeRo
I drive past that field all the time. It’s a pretty large piece of ground and it is connected to the AFB. They have an overpass on Kolb road built years ago to push aircraft over the road.
I do see people quite often on the side of the road with cameras.
If you head this way, you may want to see check the Pima Air Museum also. It’s expanded much more from years ago.
Reactions: PeRo
Thanks for your detailed suggestions! I'll give it a try.
I have no plans to fly in NFZs. Looking for spots (if any within viewing range) in compliance with the rules.
No plans to fly over the base at all. I am looking for remote spots outside of any restrictions but within viewing distance. I'll check the suggestions in your previous post. It's a pity, that tours are not offered any more.
Thanks for the idea of visiting the Pima Air Museum. If not from air, that may be another option to get a good impression of the area and related background.
The FAA's B4YOUFLY app is very handy for quickly checking on the official regulations in any location, whether you're on site or selecting the location on the screen map.
Yes, thanks! I am aware of the App. The idea was, to collect first hand recommendations for locations, complying with the regs and enabling sufficient spotting options. Local experience is unbeatable...
Reactions: MS Coast
Maybe from Pima community college east campus off Irvington? Call them. It would be a blast to FPV the yard. Irvington Rd at S Pantano, there’s a bike path…All along Irvington as you’ll see on maps you can drive or walk along and get nice ground footage. I hope that helps I’m pretty new here.
shortbrownguy
