Wi-Fi vs occusync 2.0.
I'm sure you're gonna get plenty of technical explanation here, but as long as you're waiting, you can read about it here:
Can someone give a quick rundown on why occusync is superior to wi-fi for the non tech members?
Wi Fi i very limited to a shorter distance with much more potential for a dis- connect.
There is no comparison to OccuSync 2.0 as its the best that we have right with these types of drones..
The Occusync allows for the drone to decide the best signal to use allowing you a a more secure flight in a variety of flying conditions.
This is one of the reason why the Air 2 is such a nice upgrade from the Air.
Phantomrain.org
Gear to fly your Mavic in the rain
Coal
Reactions: NAVMAV and Rchawks
its all down to the way that the signal from the RC is generated, there is a random code no that is generated when the drone and RC link and this encoded link is what keeps the signal so stable and less prone to interference, this radiated signal also produces heat and thats why the RC and drone need the cooling fans in them,all that is actually transmitted is just a stream of zeros or ones which when they reach the processor in the drone are converted back into the command made by the RC
Reactions: Rchawks
Unless I am mistaken, WiFi’s and OccuSync use the same publicly available radio bands, but different transmition methods designed for different purposes - wifi was designed for networking computers inside buildings, OccuSync was optimized for flying DJI drones.
Given DJI’s AeroScope and Drone-to-Phone initiative, OccuSync is not completely uncompatable with Wifi. That said, not sure if it is that OccuSync can send a WiFi readable signal, or an app can decode an OccuSync coded signal.
OcuSync and wifi use exactly the same frequencies for control and video download. OcuSync has more robust data exchange structures to reduce interference and weak signal issues.
I'm fascinated by the sheer range with Ocusync. I have a Parrot Anafi, and Inspire 1, and just got a Mavic Pro. The Anafi and Inspire 1 are limited to 1000 feet in developed areas, maybe 2000 feet in more rural places. The Mavic can go much further, I've even met someone who flew his several miles away. Is it really because of different protocols? It seems crazy that the same frequencies as wifi can travel so much further. Is it also much higher wattage?
It's pretty much what @Dave Maine wrote. Same radio frequencies (Ocusync uses wi-fi chipsets), but highly optimized for drone control and video downloads.
Reactions: Rchawks
Phantomrain.org
Coal
Agree, and occusync 3.0 on FPV drone is a better looking forward to being in the next camera drone.
I have a mini 1(wifi) and a air 2 (occusync 2.0).... i love the mini but only if im flying VERY close (its tiny).... occusync 2.0 on the air 2 is far superior especially if your flying around or above dense trees...
For the USA, additional range is achieved by a higher transmit power ( up to 26 dBm) compared to the typical router (20 dBm or less).
I went from a Spark with WiFi to a Mavic 2 with Occusync. With the Spark, signal would drop out even with VLOS. The Spark is a small drone, so it's not too far before it goes out of range. With the Mavic 2, the range you get is literally miles! WAY beyond VLOS and even works behind large obstacles.
I loved my Spark. It was tough as old boots and survived many a good biffing. Shame it didn't have a better gimbal and Occusync 2.
Reactions: RobotBee
Thanks - was your Spark in FCC though?
No it would have been CE as I live in the UK. However, the difference between the 2 transmission methods is astounding. Even CE Occusync allows incredible range and stability.
Has anyone compared ocusync 2.0 CE to Wifi FCC?
Yes, Ocusync wins by far.
Wi-Fi is designed for short ranges up to about 100m, so that they could customise it to get usable bandwidth out of it at 1km or more is already pretty impressive. Ocusync is built using customised LTE (4G) cellular equipment which is designed for more range in the first place.
Interesting. I've had my Mavic Air 2km away on Wifi in FCC mode, but if trees are in the way I find the signal gets blocked easily.
I don't think the CE/FCC power differences matter as much as Ocusync vs Wi-Fi. Wi-Fi is a general-purpose network technology. Ocusync is highly optimized for one set of tasks, drone control and drone video transmission.
Reactions: Greekislandlover
UR7CR
